Activity Forums Apple Final Cut Pro Legacy Export Using QT Conversion default
  • Export Using QT Conversion default
    Posted by Brad Hebert on August 11, 2011 at 1:27 am
    My office only has Final Cut Express, but I’m guessing this all still applies:
    It appears that every time I choose “Export> Using QuickTime Conversion…” the settings are H.264 and 24fps. Is this just because Apple thought it is a good place to start?
    What is strange to me is that for a DV sequence, the default resolution for export using QT is 640×480 (Current)… which isn’t the “current” right?
    And for a AIC 720p sequence, export default is 640×360 (Current)… which isn’t the “current” and is smaller than the DV export.
    Am I missing something?
    Rafael Amador replied 15 years, 1 month ago 2 Members · 1 Reply
  • Rafael Amador
    August 11, 2011 at 11:41 am
    [brad hebert]
    Am I missing something?”
    QT Conversion is standard agnostic and doesn’t care about FCs sequence setting.
    Whatever you import, without regard of size, codec, pixels,etc will be converted to what you set i the export window.
    rafael
    http://www.nagavideo.com
