Activity Forums Apple Final Cut Pro Legacy Export Using Compressor
  • Export Using Compressor
    Posted by Bronek on August 3, 2007 at 4:38 pm
    While trying to export my DVCPRO HD project from FCP (Final Cut Studio 2) using the “Export Using Compressor” option, the export seems to continually fail. Compressor says the reason is that FCP is failing. I’m in a tight time crunch – any advice would be great!
    John Pale replied 19 years, 1 month ago 4 Members · 4 Replies
  • Tom Wolsky
    August 3, 2007 at 4:42 pm
    Export a self-contained QuickTime Movie at current settings from FCP and bring that into Compressor.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Bronek
    August 3, 2007 at 4:50 pm
    Will that lessen the image quality at all?
  • Jim Martin
    August 3, 2007 at 5:59 pm
    No
    Jim
  • John Pale
    August 3, 2007 at 8:14 pm
    Export Using Compressor does not use your FCP render files…it re-renders all your effects to directly to MPEG-2 (or whatever you are compressing to in Compressor), without first compressing to DVCPRO-HD.
    This theoretically can produce a cleaner encode, but I have never been able to see a difference…certainly not enough of one to deal with the massively increased encode time.
