Activity › Forums › Apple Final Cut Pro Legacy › Export Using Compressor (HD Quality/Preset)
  • Export Using Compressor (HD Quality/Preset)
    Posted by Steve Rogers on June 24, 2009 at 2:43 am
    Hello,
    I have recorded footage (approximately 30 minutes) in HD and have the following questions:
    Q1. What is the recommended preset (for best quality) to use in Compressor to export in HD? (Note, Export Using Compressor option selected from FCP)
    Q2. Once the Compressor session is completed:
    A) Is it possible to output the footage to a standard DVD retaining the HD quality?
    OR
    B) Could exported HD footage only be deposited to a blue-ray disc? (note the end result to view HD footage).
    Steve
    Steve Rogers replied 17 years, 3 months ago 2 Members · 2 Replies
  • Jerry Hofmann
    June 24, 2009 at 3:15 pm
    File/export/QuickTime Movie…
    Use current settings, and make the movie self contained. No compression is added and this file can be played back from any computer.
    If you want to burn a blu-ray disk read this: https://www.kenstone.net/fcp_homepage/taming_the_wild_blu_2.html
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Steve Rogers
    June 25, 2009 at 2:36 pm
    Thanks for your response Jerry.
    So your recommendation is to use ‘Toast 9’ instead of any existing settings/presets in FCP/Compressor/DVD Studio Pro?
    I’ve just read through the link you provided and it appears to be useful.
    Looks like I’ll need to purchase ‘Toast 9’. This will enable my HD footage from FCP to be deposited onto a Blu-ray disc.
    Ideally, I was hoping to achieve the same result by using FCP, Compressor & DVD Studio Pro.
    Regards,
    Steve
