Activity › Forums › Adobe Premiere Pro › Export using Adobe Media Encoder
  • Export using Adobe Media Encoder
    Posted by Harikrishka on November 11, 2006 at 4:14 pm
    Hello all,
    As I like to create multiple small movies in a single DVD, I tried to create a DVD movie file using Adobe Media Encoder. I have selected Preset PAL Progressive High Quality 4 Mb VBR 2 Pass option uner MPEG2-DVD format. This created three files -> .M2V, .m2v.mcses and .wav. Then I tried with Nero Vision express to create a DVD out of this movie, but Nero is giving error that the second and third files are not of movie files.
    Can someone help me on this issue? Also can you please let me know which could be the best option (Preset & Format) to choose for a regular TV viewing movie?
    Thanks for your help.
    Hari.
    Aanarav Sareen replied 19 years, 10 months ago 3 Members · 2 Replies
  • Mike Velte
    November 11, 2006 at 9:21 pm
    If you are using Premiere Pro 2.0, why fool with Nero as Premiere can do better menus and other options.
    If your overall length is less than an hour, choose the 7 Mbps CBR preset.
    If you must use Nero, change the file extension of the M2V file to .mpg. Nero may not like a seperate .wav for the audio, so you will need to select DVD as the Multiplexing type (Multiplexer tab in the encoder) to create one file with both video and audio.
    Forget about mcmcs files.
  • Aanarav Sareen
    November 14, 2006 at 7:24 am
    I agree with Mike. I did a video tutorial on how to create DVDs with Premiere Pro. You may view the tutorial here: https://www.creativecow.net/articles/sareen_aanarav/dvd_authoring/index.html
    Aanarav Sareen
    premiere@asvideoproductions.com
