Activity Forums Avid Media Composer export too dark
  • export too dark
    Posted by Pieter Smet on October 16, 2013 at 11:58 pm
    Hello,
    I know a lot of people have had this problem but I can’t figure out what I am doing wrong.
    When I export my sequence in DNxHD (rec709) the result is as it was in Avid, but then when I convert it to h.264 (with compressor or mpeg streamclip) the result is that the blacks drop. So the image is too dark.
    When I export in RGB the result is the dark immediately.
    My workflow:
    • open AMA volume (prores and sony f5 material)
    • transcode to DNxHD 36
    • edit
    • export (DNxHD)
    • make conversions.
    QT ref hasn’t been a solution so far.
    Really don’t know what to do now, so all help is more then welcome.
    Thnx,
    P.
    Job Ter burg replied 12 years, 11 months ago 2 Members · 1 Reply
  • Job Ter burg
    October 17, 2013 at 9:28 am
    That’s the infamous H264 gamma issue in QT. Better export QT Ref or Same As Source, then transcode to x264 or Main Concept H264 in Sorensen Squeeze (you got a Squeeze serial with your MC).
