Activity › Forums › Avid Media Composer › Export to XDCAM422 50MB/s from MC 5.5?
Posted by Frank Spencer on May 23, 2012 at 1:54 pmHi
Is there any way to export an XDCAM 422 file (might be a quicktime?) form MC 5.5.
I don’t mean to get it back onto XDCAM media. I need to create this to put on a hard disc for delivery to a braodcaster.
I also have Squeeze 7, but can’t work out how to get that to do it either.
Frank
Media Composer 5.5, Win 7
PAL, UKGlenn Sakatch replied 14 years, 4 months ago 3 Members · 6 Replies -
Glenn Sakatch
May 23, 2012 at 2:14 pmI do this all the time…its quicker than going straight to disc.
You have to create a virtual XDCam drive on your computer. I have a folder setup of the XDCam structure.
Drag it to a little batch program (only works in windows) This turns your folder structure into a virtual
drive on the computer.Then launch MC (won’t recognize the drive if the program is running when you create the drive)
go output to device, and you will see an XDCam drive ready to use.After you’ve output from MC, you can copy the contents of that Virtual Drive to an actual XDCam drive, or
burn to a regular DVD for future use. I do it for commercial runs that don’t need to be XDCam yet, but i know broadcasters will be asking for them eventually. Costs me a dollar to keep an Archive of an XDCam disc sitting around.As for the method of creating the virtual Drive, i found it here.
https://dylanreeve.com/videotv/2011/virtual-xdcam.html
Pay attention to the drive letter you are assigning to your virtual drive…it can’t be one that is already on your system. (you may have to edit the batch file to accomplish this)
Also, realize that the drive that is created will have the same name as the actual drive that your folder
structure is sitting on. There doesn’t seem to be any way around this.Glenn
Frank Spencer
May 23, 2012 at 2:45 pmThanks Glenn
I’ll have a go at this. I need to deliver five programmes to a broadcaster as XDCAM422 files on a hard drive. Are they likely to be able to read these made in this way? I was expecting to have to put them in a Quicktime wrapper to make them more portable.
Frank
PAL, UK -
Job Ter burg
May 24, 2012 at 12:46 amSending an OP1a MXF file (the result of this trick) is most common when delivering to broadcasters. Better to avoid QT.
Frank Spencer
May 24, 2012 at 7:24 amExcellent.
Thank you for that. I will now take another new step along the tapeless workflow.
It just seemed odd using such a strange workaround to make a very mainstream delivery.
Frank
PAL, UK -
Job Ter burg
May 24, 2012 at 11:38 amThat’s why in v6 Avid added a ‘regular’ OP1a MXF export option that does not require you to create this virtual XDCAM disc, and also allows you to name it (like any other export).
Glenn Sakatch
May 24, 2012 at 2:11 pmInteresting, i didn’t notice that change. (our deliverys are always asking for the actual Disc, but good to know)
Glenn
