Activity Forums Adobe Premiere Pro Export to tape question
  • Export to tape question
    Posted by Joseph Herman on April 11, 2009 at 2:43 am
    Hello,
    I made a short computer animated film on my computer. Thus, the original source is not DV but an uncompressed Quicktime movie(Animation Codec).
    I may have the opportunity to have it broadcast on the local Public television station, but I must send the film in either mini DV, DigiBeta, or Beta. Since I only have a mini-DV camera, I am going to opt for that.
    I would like to know how to get it from Premiere Pro 2.0 PC to the tape since I have never done that before.
    Here are the specifications. The short, as mentioned before, is an uncompressed quicktime movie with the pixel dimensions of 720 X 405 which is a 16 X 9 (square pixels) aspect ratio. The frame rate is 24 (can switch it to 23.976).
    I suppose if I stretch the height to 480, it will be anamorphic format, but can television stations deal with Anamorphic master tapes or is that for DVD only? In any case, I can also just put black bars on the top or bottom and fit it in the 720 X 480 Standard DV format. I would like to send them the anamorphic if I can, but perhaps they cannot use it.
    The real question, is what do I do after I get the movie the right dimensions, aspect ratio and frame rate? Should I convert it somehow into the DV codec first?
    Also very important. Since the animation is 24 fps, will the Export To Tape process be able to introduce 3:2 pulldown in order to correctly play correctly on 29.97 standard television frame rate?
    What should the Premiere Project settings be?
    Thank you very much for your help.
    Joseph Herman replied 17 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
