Activity › Forums › Adobe Premiere Pro › Export to tape problems in PP 1.5
  • Export to tape problems in PP 1.5
    Posted by Martin Tiller on June 22, 2006 at 9:54 pm
    I am having problems Exporting to Tape. I am exporting to a GL2, but I have no problems captureing the footage with the GL2.
    When the footage is being played back it’s speed is erratic. Stopping, then going normal, then past, then pausing.
    The project was orginally edited on an external HD that is connected by firewire, thinking it maybe a problem with the HD exported the footage to an internal drive, created a new project on that drive, and tried to export it from there. But there was no change.
    Do I need to reinstall PP 1.5?
    What other info do I need to list to help?
    Any info is appreciated.
    Thanks in advance,
    Martin
    http://www.mctimages.com
    Martin Tiller replied 20 years, 3 months ago 2 Members · 2 Replies
  • Aanarav Sareen
    June 23, 2006 at 2:57 am
    Try this following, in any order you want.
    1) Re-install Premiere Pro 1.5
    2) Try with a different firewire cable.
    3) Try with a different firewire card.
    4) Try with a different firewire deck.
  • Martin Tiller
    June 28, 2006 at 4:53 pm
    problem sloved. My secondary drive was bad. Some how that messes everything up in windows.
    Thanks again,
    Martin
