Activity Forums Adobe Premiere Pro export to tape – audio cuts in & out
  • export to tape – audio cuts in & out
    Posted by Rhitu Basu on December 1, 2005 at 6:18 pm
    System specs : HP Media Center 854n, Windows XP, Pentium 4, 2.56 GHz processor, 2GB RAM, Video/Audio : NVidea GeForce 4 MX440 & Realtek AC’97 Audio (that’s what I found under Device Manager anyway). 2 internal drives – the one I am doing all my editing work on still has 125GB of space (I think it’s a SCSI). I also don’t have any other programs running on this machine. Only camera is connected via Firewire.
    Camera : Panasonic DVX 100A, connected via Firewire.
    Export to Tape exports video fine, audio cuts in and out. I have set all the DV Playback settings to playback on the DV hardware.
    Side note : if I export the timeline (8 minute short) to just a .avi on my hardrive, the audio is fine, the video stutters 😐 I have even tried to use this clean audio track on my project and THEN export to tape, but once again, the original problem – video is fine, audio cuts in and out.
    Please, please help me. This is due in two days and I still have editing to finish.
    Rhitu Basu replied 20 years, 10 months ago 2 Members · 3 Replies
  • Paul Corey
    December 1, 2005 at 8:00 pm
    I have a problem with video fading in and out when I used the Export to Tape but the audio was fine. I got around the problem by hit the space bar and record on the tape deck and it would work. The video did not fade and I never found out what the problem is.
  • Rhitu Basu
    December 2, 2005 at 2:05 am
    For some reason my camera won’t record in VCR mode … I must have to set smthing on it or smthing. I will try to do this, but my understanding is that Export to Tape pretty much does the same thing – my camera records the played back timeline. So there must be smthing else – hardware or Premiere Pro related that I missing that is causing the audio to drop when recording. Please help.
  • Rhitu Basu
    December 2, 2005 at 8:17 am
    Please, please someone one out there … help me.
