Activity Forums Adobe Premiere Pro Export to specific file size
  • Export to specific file size
    Posted by Chubby on May 9, 2005 at 10:01 pm
    Hi there; I’m actually using Premiere 6.0 and was wondering if anyone knew of a setting, or other program, I could use to export my final video to a specific MB file size rather than a specific video demension. Thanks in advance.
    Steven L. gotz replied 21 years, 4 months ago 2 Members · 3 Replies
  • Steven L. gotz
    May 9, 2005 at 11:45 pm
    Lots of variables to deal with. Some experimentation will get you close. But every video requires a different amount of compression based on the content. So until it is compressed, you can’t really know the exact size. You can, however, get pretty close.
    I do not know of any software designed to get you a specific file size. Perhaps one of the encoders like Canopus Procoder or Sorenson Sqeeze does?
    Steven
    Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Chubby
    May 10, 2005 at 12:00 am
    Hi, Steven, thanks for the reply.
    I’ve toyed around with different predefined outputs, but the size produced is either higher or less than my client wants. I guess what I’m looking for is something that will produce the final video within a certain range.
    Thanks again.
  • Steven L. gotz
    May 10, 2005 at 1:25 am
    Just experiment until you get it right. If you use a constant bit rate you can get it very close. With variable, which usually looks a bit better, it is harder. No magic to constant bit rate. Just math.
    Steven
