Activity Forums Adobe After Effects Export to several files by markers, not with work area
  • Export to several files by markers, not with work area
    Posted by Lali Malmborg on April 19, 2011 at 9:57 am
    Hello
    I’m sorry if this question has been asked before, but I can’t seem to find it. Maybe I does’nt search with the right words.
    Well, I’m looking for a way to export several movies triggered by my Comp Markers.
    For example marker one to two exports to one movie, and two to three a diffrent one in a kind of batch-sequense. Couse it’s to time consuming to move the work area and click render a hundred times.
    Thanks for your time!
    /Lali, Sweden
    Lali Malmborg replied 15 years, 4 months ago 2 Members · 4 Replies
  • Lali Malmborg
    April 20, 2011 at 6:58 am
    It’s not about how long it is. The thing is that it will be used as a template for others to render from. So it is a DVD menu with a few menus and a few transitions. To be adapted to clients’ personal preferences. Mostly change name and photos.
    Anyway, I precomposed the main comp and then I did manually several “rendercomps” such as “intro” “transition to main scenes” main menu “and so on.
    And it works. Now, my colleagues, who will use the template, get a little less to think about.
    I was looking however for a faster workflow. Thought markers would do the trick, But maybe not …
  • Angie Taylor
    April 20, 2011 at 1:21 pm
    Not sure if this Layer Markers script might help you;
    This script has two functions. It can split selected layers at their layer markers, or add markers at the cut points of any layers in a comp. This can help with comp navigation and more. Watch the demo video for details on how to use the script.
    https://aescripts.com/pt_layermarkers/
    cheers,
    Angie
    Angie Taylor animation & illustration for television, film, web and devices
    https://www.angietaylor.co.uk
    Twitter: theangietaylor
    Linkedin: theangietaylor
    https://www.facebook.com/pages/Angie-Taylor/118378194869002
  • Lali Malmborg
    April 20, 2011 at 1:46 pm
    Hi
    Well, I saw this script googling too, but I don’t really wanna split upp my comp. I just like to mark a certain duration, call that #1, and mark another duration and call that one #2. Then render each of them into a separate file with a single click. It would make my work so much easier.
    Am I the only one who misses this way of work?
  • Lali Malmborg
    April 22, 2011 at 7:39 pm
    Hi again.
    My comp is a DVD-menu, as I stated before. It’s the fly intro, the main menu, fly off to scene selection, scenes selection and the fly back to main menu. Everything in a linear form. Then the different selections shall be rendered out in separate MPEG’s. It will be used for X different projects so it has to be easy to customize and easy to render.
    The only way to do this that i figured out was to pre-comp everything and then make five comps; intro, main menu, fly to scenes, scenes, fly from scenes to main; and then drop the everything-comp into them. And line them up correctly in time.
    What I was wondering about was if it was possible to mark selections in the master comp that could be automated in the rendering-process to split up in my five separate MPEG’s.
    Hope I cleared out what I was asking. (It’s kinda hard explaining something in a language that is’nt my mother tongue! =) )
