Activity Forums Apple Final Cut Pro Legacy Export to Quicktime takes forever
  • Export to Quicktime takes forever
    Posted by Billu Patel on February 3, 2011 at 6:35 pm
    Hello all,
    I’m facing a peculiar problem with FCP7. I’m trying to export a 640×480 H.264 sequence (export to quicktime) and it has been 10hrs since I started it. At this moment it says 47hrs remaining and 14% done!! What gives? I was able to export other similar sequences last week in around 4hrs or so.
    I hardly did any editing to the stream. I just added an image at the beginning and at the end.
    Just to make sure I have enough space I have deleted other stuff left by projects in FCP folder in My Documents and the disk still has around 45GB empty.
    Thanks.
    Chris Tompkins replied 15 years, 7 months ago 2 Members · 3 Replies
  • Chris Tompkins
    February 3, 2011 at 9:52 pm
    FCP does not like H.264
    This is not an editing codec.
    This has been covered SO many times on the COW.
    Chris Tompkins
    Video Atlanta LLC
  • Billu Patel
    February 3, 2011 at 10:00 pm
    I’m not editing in H.264 ….. I’m export “to” H.264.
    Last week while doing the same, it was able to export to H.264 in about 4hrs or so. I wanted to know why it says it will do the same job in more than 2 days! CPU is always at around 180% use by FCP!
  • Chris Tompkins
    February 4, 2011 at 11:24 am
    Sorry, I miss-read.
    Have you tried exporting “current settings” and then dropping that file in compressor to make your delivery clip?
    Chris Tompkins
    Video Atlanta LLC
