Activity Forums Boris FX export to quicktime renders with black background _ no alpha channel
  • export to quicktime renders with black background _ no alpha channel
    Posted by Donald Thompson on October 13, 2005 at 1:09 pm
    I have had trouble the last 2 weeks exporiting quicktime movies with alpha channels. The movie export settings are:
    alpha _ straight
    compression type _ DV/DVCPRO
    Lower Field
    High Quality
    better quality field rendering
    I have reset the factory settings and reset tab setting.
    Thanks in advance for your responses.
    Donald Thompson replied 20 years, 11 months ago 3 Members · 5 Replies
  • Donald Thompson
    October 13, 2005 at 3:22 pm
    The previous message should have includedl: Does anyone know why I cannot export a QT movie with the alpha channel?
  • Markmc
    October 14, 2005 at 11:41 am
    Dv codecs don’t contain alpha channels Choose the animation or none for codec.
  • Donald Thompson
    October 14, 2005 at 1:25 pm
    I have tried the animation and “none” settings and the QT file still renders with a black backgound. Viewing the composite window while playing down the timeline I see the checkerboard pattern. When the movie file is rendering the black background shows in the composite window during the render.
  • Tim Rice
    October 14, 2005 at 2:01 pm
    When rendering with the animation codec make sure million colors + is highlighted (the plus means alpha channel).
    HTH,
    Tim
  • Donald Thompson
    October 17, 2005 at 3:45 pm
    Millions+ was the answer. Thanks so much.
