Activity › Forums › Adobe Premiere Pro › Export to QuickTime Movie
  • Export to QuickTime Movie
    Posted by Bok Toh on September 13, 2011 at 2:14 pm
    My raw video footages are shot at 1920 x 1080P, 29.97fps and my sequence settings are the same. The final video is going to be played using QuickTime Player and I have determined that 720×480 dimensions suit the best. There are so many export settings available, so which one should I choose to produce the best quality?
    Thanks.
    Jeff Greenberg replied 15 years ago 2 Members · 1 Reply
  • Jeff Greenberg
    September 13, 2011 at 4:25 pm
    I’m assuming that if you’re going to use 720×480, that you’re exporting SD, meant for a video playback – and likely we’re talking widescreen NTSC. Use Adobe Media Encoder (which is what happens when you press export Media); choose MPEG2 – DVD and then choose NTSC Widescrreen high quality.
    If I’m wrong in that assumption (you’re doing a DVD) let me know – the choice of 720×480 may be incorrect if you’re intending web playback/computer playback.
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    New- my book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
