Activity › Forums › Adobe Premiere Pro › Export to Procoder
Export to Procoder
Posted by Ahill on April 6, 2005 at 8:55 pmHaving issues with exporting to ProCoder 2.0, both the normal export and Wizard. App locks up and/or error message. I am using Pro 1.0, any suggestions?
Ahill replied 21 years, 5 months ago 2 Members · 8 Replies -
Ahill
April 7, 2005 at 6:20 pmI should have written it down, however I’ll try to explain what is occurring. The timeline is about 1hr 35min the one error message that appeared was after the timeline was rendered and right before the encoding began, the app has been locking up before I can get the message again. I ran a test with an edited shorter clip (same source) of about 1min and it worked fine. Is there a limit on duration or file size for exporting clips? Also when I try to use the Premiere export feature to AVI with the Canopus Codec, I get a “Error compiling movie or codec compression error.” message.
Aanarav Sareen
April 7, 2005 at 6:29 pmA wild guess, but did it say “Adobe Premiere Pro failed to return a video frame”?
Aanarav Sareen
April 7, 2005 at 8:03 pmOk. Make sure that you don’t have any gaps in the timeline that you are trying to export.
Aanarav Sareen
April 7, 2005 at 11:15 pmTurn of the hyperthreading in your system and that should do it. If not, then head over to the Adobe forums as there have been a lot of complaints about this same problem.
