Activity › Forums › Adobe Premiere Pro › Export to Panasonic P2 Crashing
Posted by Nick Marques on March 11, 2008 at 2:15 pmHello,
I have an DVCPRO HD 720p project setup with some HDV footage in it. I’m using this project to use the Export to Panasonic P2 feature so that I can better use this footage with other P2 720p files.
This export goes for any random amount of time, then Premiere Pro will crash due to the file ntdll.dll . Any ideas?
This is putting 100% load on my Q6600 quad-core the entire time, but so do other exports that don’t crash.
The last time it crashed, it happened at 95% completion, which took about 2 hours.
Nick Marques replied 18 years, 6 months ago 2 Members · 8 Replies -
Vince Becquiot
March 11, 2008 at 4:26 pmHave you tried exporting without the HDV footage?
P2 is in is infancy in Premiere, there are other issues such as unlinking and relinking that are causing crashes. I even have seen a couple of crashes when importing too many clips, although not lately.
I find that the export to P2 stops working if I mix in QT animation as well. I hope these bugs will get worked out on the next version…
Vince
Vince Becquiot
March 11, 2008 at 4:30 pmOne last thing, is your timeline render setting set to uncompressed or DVCPRO HD ?
Try deleting the render files, then render again (to DVCPRO HD) before export.
Vince
Nick Marques
March 11, 2008 at 4:56 pmWell, I’m just doing this to convert HDV, so doing an Export without HDV isn’t an option.
Are you saying I should render the work area before I do the Export to P2? Doesn’t the Export to P2 do the same thing at the same time? If I wait the time for the Render Work Area to complete, does this speed up the Export to P2?
Vince Becquiot
March 11, 2008 at 5:18 pmYes, it will speed up rendering. So, let me get this straight… You are working in a P2 timeline or HDV timeline ?
I’m guessing HDV since the aspect ratios and decoders have nothing in common. If that’s the case, that’s pushing the P2 export even further to the edge, I didn’t even know that would work.
I did get the QT animation footage to export to P2 after rendering, so you may want to try exporting to that first instead of directly to P2. Either way, I hope you’re not on a deadline.
Cheers,
Vince
Nick Marques
March 11, 2008 at 5:37 pmHaha, no pressing deadline.
It’s a DVCPRO HD 720 Project and Timeline with HDV 1080i footage in it. I’m doing the P2 Export to convert it to 720p.
We have a Matrox RT.X2 and for whatever reason, the Export to Panasonic P2 is grayed out completely while not in an Adobe editing mode.
If I can get all of my assets the same type (720p in this case), the RT.X2 can allow real-time editing much better.
Vince Becquiot
March 11, 2008 at 6:12 pmGot it… Well, again, the intermediate QT animation export should work. Though, unless your final format is DVC PRO HD, you will really take a quality hit on the HDV.
Vince
Nick Marques
March 12, 2008 at 7:34 amJust a little update…
With 2 hours of HDV 1080i footage in this 720p project, it took about 10 hours to render the preview files.
Then, doing the Export to Panasonic P2 took about 5 hours. I have no idea why it takes this long… CPU usage sky rockets to 100% for all four cores (Intel Core 2 Quad Q6600 2.4 Ghz).
I guess doing the render preview didn’t help much, except that so far it hasn’t crashed.
I thought about just grabbing the preview renders and using those, except the filenames are all weird.
Nick Marques
March 12, 2008 at 8:09 amActually, I lied… It takes the same 10 hours to Export to P2. I forgot that I only did half of it for that 5 hour number.
