Activity › Forums › Avid Media Composer › Export to OMF Fails Instantly
  • Export to OMF Fails Instantly
    Posted by Phillr on April 22, 2006 at 9:55 pm
    I’m trying to export my timeline into an OMF format, because I’ve been told it’s faster to import into my timeline because I use an Avid Meridien-based editing system (PC).
    I set up my render queue, using 1:1 compression. When I tell the queue to Render, it stops with an error msg “Failed at #######”. The first frame. Even if I change the export start time, it still fails at the new first frame. Any idea what’s going on?
    Jon Zanone replied 20 years, 5 months ago 2 Members · 5 Replies
  • Phillr
    April 22, 2006 at 10:44 pm
    whoops, forgot to mention i’m exporting a composition from After Effects 6.5.
  • Jon Zanone
    April 23, 2006 at 4:01 am
    What version software, OS, etc…. AND what QT version are you using?
    Jon
    “The Almighty tells me He can get me out of this mess. But He’s pretty sure you’re F%$#*D!”
  • Phillr
    April 23, 2006 at 3:43 pm
    After Effects 6.5, Xpress 4.6, Windows 2000, Quicktime 6.5
  • Jon Zanone
    April 24, 2006 at 12:43 am
    According to the specs I found (https://www.avid.com/products/datasheets/xpressdv.pdf), 4.6 is approved to work with XP SP1 (SP2 wasn’t used until 5.X)….
    Has your export ever worked?
    Jon
  • Jon Zanone
    April 24, 2006 at 12:45 am
    Never mind – I just saw your other post saying you are on a Meridian system. I missed the part where you said that….
    Jon
