Activity Forums Apple Final Cut Pro Legacy export to motion jpeg A
  • export to motion jpeg A
    Posted by Ace Cruz on March 8, 2008 at 6:09 pm
    Hello,
    Can anyone help me figure out how to export a Motion jpeg A or cinepak compression off my FCP 6? My audio guy says he needs either one of these two codecs to import into his pro tools session.
    I tried going to the export tab, then hitting quicktime conversion, hitting option to change the compression type, but there is no file for cinepak or Motion jpeg A on the list to do an export.
    Although when I go to the sequence settings there is a menu to set the video settings tto motion jpeg, but only on the timeline.
    Any suggestions.
    appreciate the help.
    ace
    Julien-robert Legault salvail replied 16 years, 8 months ago 6 Members · 11 Replies
  • 11 Replies
  • David Roth weiss
    March 8, 2008 at 6:37 pm
    Ace,
    I went and checked the settings I used to do for Motion JPEG-A for my sound guy in QT Conversion and found that apparently Apple has dropped support for it. I did try to do the same thing using MPEG Streamclip (freeware) and it is supported in that app. So, export a reference clip from FCP and drop it into Streamnclip and choose “export QT” and pick Apple Motion JPEG A.
    David
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
  • Jerry Hofmann
    Oddly enough, I can find the Cinepak codec in media manager’s re-compression option… you’d need to export the finished movie as a reference movie, then open that in media manager (after reimporting the ref movie into FCP) and select recompress.. the Cinepak codec is availalbe there. That should give him a single video/audio file that is compressed using the Cinepak codec.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • David Roth weiss
    March 8, 2008 at 7:01 pm
    Its just so odd that the Apple engineers would bother to make changes that seem to have no reason for being, such as removing Motion JPEG-A from QT Conversion, meanwhile never touching things for years that everyone knows need tweaking. Its as if they need a TO DO LIST…
    A TO DO LIST is by the way apparently one of the biggest things missing from the iPhone according to many user polls, so apparently this may be a company-wide problem.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Jeremy Garchow
    March 8, 2008 at 7:35 pm
    Quicktime 7.3.1 or higher?
    Open the Quicktime System Preferences:
    Apple menu > System Preferences > Quicktime. Click on the advanced tab and choose “Show Legacy Encoders”.
    Jeremy
  • David Roth weiss
    March 8, 2008 at 8:02 pm
    Get a life Jeremy… Have you got nothing better to do than digging into the hidden recesses of QT?
    Good find!!!
    Have a good weekend…
    David
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Jeremy Garchow
    March 8, 2008 at 11:45 pm
    [David Roth Weiss] “Get a life Jeremy… Have you got nothing better to do than digging into the hidden recesses of QT? “
    Yeah, I know. Sad ain’t it? It’s 20 degrees and snowing here. What else do you want me to do?
  • Jerry Hofmann
    March 9, 2008 at 9:11 pm
    I’d be skiing in that snow…
    Jerry
  • Jeremy Garchow
    March 9, 2008 at 10:26 pm
    🙂 In Chicago? Perhaps if my neighbors and I push enough of it together from all across the city, we might be able to make a mountain.
  • Jerry Hofmann
    March 9, 2008 at 11:09 pm
    There is such a thing as “cross country” skiing… OR you could pile it up against one of the buildings then take elevators up to the roof and ski down!
    Jerry
  • Chris Borjis
    March 10, 2008 at 4:45 pm
    Ace you might consider a DV quicktime, it will
    export faster (much faster) not only that, but
    protools has the ability to output a dv signal
    via firewire to an analog converter and sweeten
    from a tv or monitor.
    This is perfect for studios that used Doremi V1
    disk recorders for sweetening.
