Activity Forums Adobe Premiere Pro export to flash lib error PP CS3
  • export to flash lib error PP CS3
    Posted by Scott Cary on December 15, 2009 at 4:56 am
    exporting a video from PP CS3 to flv using media encoder I encounter the following error;
    OMP abort: Initializing libguide.lib, but found libguide40.dll already
    initialized. This can cause performance degradation.
    Set enviroment variable KMP_DUPLICATE_LIB_OK=TRUE if you want your program to
    continue in this case
    I found a post with what seemed the same situation but was not resolved.
    Thanks in advance
    Scott Cary
    Scott Cary replied 16 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
