Activity › Forums › Apple Final Cut Pro Legacy › Export to fit to DVD
Posted by James Bishop on May 15, 2009 at 4:36 pmI’ve finished my project, which is 25minutes long…
I tried exporting it using Quicktime Movie, DVDNTSC 48Khz, but it ended up being 5.6GB. I need to get it to 4.7GB in order to fit to a DVD.
please help! thanks
John Fishbackreplied 17 years, 4 months ago 2 Members · 3 Replies
John Fishback
May 15, 2009 at 10:19 pmIf you want the program to play from the DVD you need to use Compressor to encode a mv2 and an ac3 file of the program and then use DVD Studio Pro to make a DVD using the mv2 and ac3 files.
If on the other hand you want the DV data to be on a DVD to bring it somewhere or archive it, use Toast or a similar app to put it onto two DVDs. Toast will make it so the file can be reassembled later.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
24″ TV-Logic Monitor
Final Cut Studio 2 (up to date)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
James Bishop
May 18, 2009 at 2:10 pmThanks for the response.
I want to be able to play it from DVD. My Compressor, for some reason, doesn’t work. Is their any other way of exporting it, as a file that might shrink it to 4.7gb?
James
John Fishback
May 18, 2009 at 4:13 pmOther than converting the file to another codec you can’t substantially shrink the file. And DV won’t play directly off a DVD. See if this helps you get Compressor working. https://support.apple.com/kb/TS1888?viewlocale=en_US
Another thing you can try is Import the DV movie into DVD Studio Pro. DVDSP will encode it to a mv2. However, the quality won’t be as good as Compressor.
If you need more help with Compressor and/or DVDSP post in the Apple DVD Studio Pro forum.
John
