Activity › Forums › Apple Final Cut Pro Legacy › Export to FCP still needs rendering and pixelates
  • Export to FCP still needs rendering and pixelates
    Posted by Anthony Shelton on January 28, 2010 at 10:18 pm
    I looked under “Playback Quality Is Blurry/Interlaced/Low Quality/Crappy” FAQ and while I am having that problem of not having an external monitor of some sort, I think there is a little bit more to my problem.
    I do want to say that the video I am making is going only to the web. I say that just in case that helps.
    Yes, what I am viewing in my Canvas is blurry but it is only one clip and none of my other clips are blurry in the canvas. I exported footage in QT to match my DV – NTSC Easy Setup in FCP and I get a dark green render bar. Before I render it looks fine. After I render it, it looks crappy. Knowing that it could be the external monitor issue, I exported the footage and it still retains its blurriness.
    Not only that, when I add a Cross Dissolve or Fade In to Fade Out transition, I have to render and that segment becomes blurry. Also after an export, it stays blurry.
    The clip matches everything that the Easy Setup has so how come I have to render and since I do, why is it making my content blurry?
    Thank you for the help and I apologize if the answer turns out to be dealing with an external monitor.
    Michael Gissing replied 16 years, 8 months ago 5 Members · 12 Replies
  • 12 Replies
  • Shane Ross
    January 28, 2010 at 10:43 pm
    [Anthony Shelton] “The clip matches everything that the Easy Setup has so how come I have to render and since I do, why is it making my content blurry?”
    If it matched exactly, then you wouldn’t need to render. Something is off…it has to be. Double check ALL the settings…the CLIP settings of the footage, and the SEQUENCE settings.
    Shane
  • David Roth weiss
    January 28, 2010 at 10:56 pm
    And, keep in mind that, if the sequence settings were changed after the media was already on the timeline, that would create an issue even if the setting match the media. So, a match is not always the perfect match.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Anthony Shelton
    January 28, 2010 at 11:03 pm
    This is a screenshot of the comparisons. The sequence settings are on the left.
    If you can’t see them here they are written out:
    SEQUENCE SETTINGS:
    Vid Rate: 29.97
    Frame Size: 720×480
    Compressor: DV/DVCPRO – NTSC
    Pixel Aspect: NTSC – CCIR 601
    Field Dominance: Lower (Even)
    CLIP SETTINGS :
    Vid Rate: 29.97
    Frame Size: 720×480
    This is what they are so unless I’m missing some aspect of my clip settings then I’m not sure why this happening. Again, thank you for the help.
  • Anthony Shelton
    January 28, 2010 at 11:07 pm
    [David Roth Weiss] And, keep in mind that, if the sequence settings were changed after the media was already on the timeline, that would create an issue even if the setting match the media. So, a match is not always the perfect match.
    Yep. I did not change any of the sequence settings at any time once I put a clip in the timeline. I made sure everything was what I needed it to be before I placed anything in the timeline.
  • Michael Gissing
    January 28, 2010 at 11:22 pm
    There are many ways to make the render bar appear on a clip that matches the sequence settings. Are you adding any title supers to the shot? Are you adding any filters? Have you changed size or distort in the motion tab or applied any rotation to the shot?
    Check the motion and filter tab settings to see if there is something going on there.
  • Anthony Shelton
    January 28, 2010 at 11:30 pm
    To this particular clip, I am not adding anything. The only thing I’ve done to the clip is place in’s and out’s and dragged it to the timeline. That’s all I did. ^_^
  • Michael Gissing
    January 29, 2010 at 1:24 am
    Did you check the Motion and Filter tabs?
  • Anthony Shelton
    January 29, 2010 at 2:26 am
    I’m not at my office anymore but no I didn’t check those. But I know I never did anything to them. Like I said, all I did was add in and out points and dragged it to the timeline. ^_^
  • John Pale
    January 29, 2010 at 5:29 am
    I am guessing somehow the shift fields filter automatically got added. look in the filters tab.
    remove it and you should be good.
  • Michael Gissing
    January 29, 2010 at 5:40 am
    I am not concerned with what you have done, but FCP can add filters like the shift field and it can change size and distort settings, particularly if anamorphic flag settings are not right.
    So if you can check those tabs and if necessary remove any filters and reset distort and motion settings, the need to render and the resulting degrading of you picture may be fixed.
