Activity › Forums › Adobe Premiere Pro › Export to DVD from PP2
  • Export to DVD from PP2
    Posted by Dong Le on April 29, 2008 at 5:50 pm
    I am unable to export to DVD from PP2 when ever the target is bigger than 4.7GB . Not even to export to a folder on my hard drive which have lot of spaces.
    Please help.
    Thanks a bunch.
    Vince Becquiot replied 18 years, 5 months ago 2 Members · 1 Reply
  • Vince Becquiot
    April 29, 2008 at 6:13 pm
    Well, a DVD ONLY HAS 4.7 GB of available space. Premiere will only let you export within DVD specs, even to a folder.
    You can purchase Dual layer DVDs if you own a dual layer burner, and you can almost double that, although the consumer version is far from perfect, and the DVDs may not play in some set top players.
    You can also export to Mpeg2 and go wild on size and bit rate, but it won’t be burnt onto a DVD.
    Vince
