Activity Forums Adobe Premiere Pro Export to DVD – EXTREMELY SLOW !!!!!!! – Why ????
  • Export to DVD – EXTREMELY SLOW !!!!!!! – Why ????
    Posted by Joe Landau on October 17, 2005 at 7:42 pm
    I have plenty of memory & disk space. My project file is on a different drive than my work files. Export to DVD for a 1/2 hour DVD has is still running after 3 hours. I have a Dell Expiron 9300 with tons og HD and 1G memory. What can I do to improve performance?
    Joe
    Joe Landau replied 20 years, 10 months ago 5 Members · 9 Replies
  • 9 Replies
  • Steve Freebairn
    October 17, 2005 at 8:42 pm
    If you meant the Inspiron 9300, then that means that you are using at max a Pentium M 2Ghz processor with 533MHZ FSB without HT. Premiere runs on equipment like yours, but doesn’t run very fast. Note the 3 GHZ recommended speed on the System requirements. Adobe Media Encoder AKA MainConcept’s mpg encoder uses Hyper Threading, so that is a second reason why it is slow. If you don’t have to run it on a laptop, then don’t. Since laptops usually have slower hard drives, slower videocards, and slower processors (especially if it isn’t plugged in and it is using speedstep to save battery.) To make it faster, close any other open programs, plug it into wall power, and give it more processor. If you meant a different system than I though, then only some of the above info might apply. Good Luck.
  • Joe Landau
    October 17, 2005 at 9:50 pm
    Thanks for your response.
    Yes, it is an Inspiron 9300.
    After about 4 hours, the program finally reached the point where the “Overall Process” reached the max. However, it is stuck there and nothing happens. “Current Task Progress” indicates
  • Steve Freebairn
    October 17, 2005 at 10:24 pm
    As for why the process is stopping at that point, I do not know. I’m sorry that you wre led to believe that a laptop would be great for multimedia, dollar for dollar, no laptop can compete with a desktop because Size and Portability are what laptops are all about. If you wait long enough some genious here on the cow will probably be able to tell you how to fix it. My only thought is to make sure all of your drivers are current.
  • Aanarav Sareen
    October 17, 2005 at 11:34 pm
    Steve,
    Your analysis of Pentium M vs. Pentium 4 is incorrect. I have a Pentium M 2.0 processor and it is faster than my Pentium 4 3.2ghz w/HT processor. Also, there are certain laptops such as the Inspiron 9300 that are much more powerful or equivalent to desktops. If you have sometime, I would reccomend taking a look at a few benchmarks.
    Joe,
    Reduce the quality slider down to 3 and it will drastically reduce your rendering time, without reducing the quality.
    Aanarav Sareen
    Adobe Certified Expert, Premiere Pro
    https://www.asvideoproductions.com/video
  • Aaron
    October 18, 2005 at 12:56 am
    https://www.adobe.com/support/techdocs/330380.html
    I think I had the same problem. The above solution by Adobe solved my issues.
    Hope this helps.
  • Steve Freebairn
    October 18, 2005 at 1:11 pm
    Aanarav, can you post a link to some of these benchmarks? I’m always interested in finding out what has the most speed. I know that the Pentium M processor is quite powerful, even more powerful ghz for ghz than the p4 because of the Netburst architecture, but the only benchmarks where I’ve seen a Pentium M beat a P4 is when the Pentium M is highly overclocked. Anyway, can you post a link so I can update my info? Thanks
  • Aanarav Sareen
    October 18, 2005 at 5:19 pm
    Steve,
    Researching a bit. But, here is an older article which was written prior to the release of the current Pentium M processor with the Sonoma chipset:
    https://www.gamepc.com/labs/view_content.asp?id=gmso&page=1
    Let me find the other ones.
    Aanarav Sareen
  • Tim Kurkoski
    October 18, 2005 at 5:27 pm
    The unasked questions:
    1. What kind (format) of footage is in the timeline? AVI, MPEG, JPEG, etc.
    2. What effects, transitions, etc. are applied to the footage?
  • Joe Landau
    October 18, 2005 at 5:42 pm
    1. The clips are all AVI files (5 of them) that I generated from other Pro projects.
    2. There are 4 transitions – Cross Dissolve.
    That’s it. Couldn’t be simpler !!!
    Thx
