Activity Forums Adobe After Effects Export to AVI Problem
  • Simon Bonner
    July 25, 2008 at 5:20 pm
    I don’t know exactly what’s going on, but thought I would make sure when you say export that you mean render. Are you using the render queue or the export command? It’s always better to use the render queue if you have the option. Try rendering the comp as lossless and see what happens.
    Simon Bonner
    youtube.com/simonsaysFX
