Activity › Forums › Adobe Premiere Pro › export to apple prores 422 in premiere cs5 on a mac
Posted by Andre Van suntenmaartensdijk on December 9, 2010 at 8:41 pmI work on a new mac with adobe cs5. I do all my editing in premiere.
Now i need to deliver sd and hd movies in quicktime proress 422, but this option is not availeble in adobe premiere or AE. Is this not a standard codec for a mac?Andre Van suntenmaartensdijk replied 15 years, 7 months ago 5 Members · 10 Replies -
Kevin Monahan
December 10, 2010 at 3:03 amI would not say it’s standard. You have to have Final Cut Studio installed on the same machine for exporting to ProRes.
Kevin Monahan
Sr. Content and Community Lead
Adobe After Effects
Adobe Premiere Pro
Adobe Systems, Inc.
Follow Me on Twitter! -
December 10, 2010 at 5:32 amThank you Kevin. Buying fcp just for a codec is not going to happen.
Goodbye apple proress.
Tim Kolb
December 10, 2010 at 5:23 pmIf you have an HDSDI or analog component output card on your machine, you could buy (or rent) an AJA KiPro and use it like a VTR…it will encode all incoming signals to ProRes.
It’s so weird to hear of someone saying they won’t buy FCP for a codec…so many seem to (at least when making the case for FCP over PPro to me) do exactly that.
In fact, I’d surmise from the way Apple has it tethered directly to FCP, even more than QT, that was exactly the intention. Overall it seems to be working for them on many levels…
TimK,
Director, Consultant
Kolb Productions, -
December 10, 2010 at 8:23 pmWell anyway, i already found a workaround. Thanks for your effort, folks.
Shawn Miller
December 10, 2010 at 10:11 pm“…so many seem to (at least when making the case for FCP over PPro to me) do exactly that.”
Wow, I would not have guessed that. I have heard FCP users say that transcoding or re-wrapping native file formats (.mxf, .r3d, etc) to Prores is a better workflow than being able to edit those files directly… but buying FCP *for* Prores? I’m not judging here… I’m just honestly surprised. To each their own… I would still be using Video Toaster on the Amiga… if it still existed. 🙂
Shawn
Bob Smith
January 5, 2011 at 2:57 amWhy not use FCP 7 to edit your video. Yesterday, i read a news about apple prores 422 from macnn.com. They recommended a powerful software called foxreal video converter for Mac. Which can Convert videos to Apple ProRes 422 for FCP 7 easily. You can try it.
January 9, 2011 at 8:17 pmFcp? No thanks. Used it, but don’t like it. premiere works so much easier and therefor faster.
Bob Smith
January 13, 2011 at 6:03 amI just tried this software called Foxreal Video Converter for Mac which recommended macnn (https://www.macnn.com/articles/10/12/31/converter.works.with.hdv.avi.mkv.tivo.more/), it can convert ProRes 422 video to many popular videos. I think u can try it to convert ProRes 422 to Premiere CS5. Hopefully it can help u.
Tim Kolb
January 13, 2011 at 2:10 pm1. If you want to encode to ProRes, you have a pretty narrow range of options. A Mac with FCP or an SDI interface and an AJA KiPro.
2. If you have ProRes, PPro on Mac or Windows will run it no problem.
3. If you need to convert TO ProRes…see item 1.
(A conversion utility or anything else on your Mac system can write to ProRes…as long as FCP is installed.)
Complaints?…Adobe is not the “A” company to complain to…
TimK,
Kolb Productions, -
January 13, 2011 at 8:45 pmNow i’m already done with this project i will tell you what i’ve done. I used an old mac with an old version of fcp on it to encode all the SD files to prores and mpegstreamclip for the HD mpeg2 files.
I like ppro because i can import almost everything. In fcp i have to convert everything. I’m not complaining, i’m switching back to ppro.
I’ve been working for two months with cs5 now and it is really good.
