Activity › Forums › Adobe After Effects › export to 32:9
  • Roland R. kahlenberg
    October 28, 2013 at 2:43 am
    AME should be ideal if you’re going to use one of Adobe’s app.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
  • Paco Fernandez
    October 28, 2013 at 8:56 am
    I think I have not explained well. When I try to export a movie to quicktime with H.264 codec from after effects prevents me from formatting restrictions (maximum 2000 px) my movie is 3840 x 1080. It occurred to me export a sequence of pngs and then from quicktime QT export the output to H.264 and it works, the results are not very good (the film lacks contrast), by the way if I try to do the same from AME not work (restrictions format). I decided to try to climb the contrast of the movie before exporting a sequence of pngs. Do you think this is the best method? Thanks in advance and sorry for the extension
    post.
