Activity Forums Maxon Cinema 4D Export TGA seq from C4D
  • Export TGA seq from C4D
    Posted by Marc Lucas on February 17, 2011 at 11:38 pm
    So I’m having big problems with crashes due to the C4D QT agent and haven’t got to the route of the problem yet so I’m reverting to exporting to TGA sequences for output. The last render I did the TGA files were 1sec 20 frames long where do I set the length of the TGA files so things play smoothly (25 fps)
    Mmmm.
    Adam Trachtenberg replied 15 years, 3 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    February 18, 2011 at 4:35 pm
    You should import the sequence into a compositing application or editor and then compile them into a video format for viewing.
