Activity Forums Zaxwerks export texture with .obj file
  • export texture with .obj file
    Posted by Theo Van laar on February 1, 2014 at 11:48 pm
    Hello,
    I’m working with Proanimator 7.01 stand alone on a Windows 7 computer. I exported an obj file from a 3D text. I also would like to export the texture. The way I tried it is by FILE-COLLECT FILES. Then a SAVE AS window opened, but I’m not able to save anything.
    What is the right procedure to save textures for obj files?
    Thanks for your help.
    Theo
    Theo Van laar replied 12 years, 7 months ago 2 Members · 2 Replies
  • Edward Wu
    February 4, 2014 at 12:01 am
    Hi Theo,
    ProAnimator does not export an .obj file with the texture map. It does export the UV mapping coordinates, but you will need to re-apply the texture in whatever 3D program you are working with.
    The Collect Files command is used when moving a ProAnimator project file from one computer to another computer.
    If you have any questions, please let me know.
    Best,
    Edward
  • Theo Van laar
    February 4, 2014 at 10:17 pm
    Thanks, I will look into this!
    Theo
