Activity Forums Blackmagic Design Export Sync Issue
  • Export Sync Issue
    Posted by Paul Jones on October 9, 2008 at 9:30 am
    I’ve posted this on the FCP forum but will also try here.
    I am running the latest version of FCP and have the latest Decklink HD Extreme card fitted.
    My problem is when I export anything to a self contained movie file out of Final Cut Pro it is 5 frames out of sync.
    If I move the audio back 5 frames and re-export then it is fine.
    It is also the same when I export to any format via compressor
    I have looked at all the possible settings I can find and no joy.
    Any help on this would be appreciated
    Paul Jones replied 16 years, 8 months ago 2 Members · 2 Replies
  • Jon Ackerman
    December 8, 2009 at 10:15 pm
    I have been having this same issue. I don’t understand what happened, but I didn’t change anything and yet everything I export is off, and it varies with each export. I think that there is something going bad with my Decklink Extreme HD card….
  • Paul Jones
    December 14, 2009 at 2:16 pm
    Well I had my card changed and still the same.
    I’ve had no replies on this either apart from you !!!
