Activity Forums Adobe Premiere Pro Export subclips
  • Export subclips
    Posted by Pieter Smet on September 9, 2017 at 3:33 pm
    Hello,
    I’m new to premiere.
    The director wants to watch the footage at home, so I have to export rushes with name and tc burned in.
    I synchronised all the audio with the video, so now I have subclips per scene. Every scene is a bin. When I export all these subclips, it only exports a very small part of the clip, sometimes the clip is black while all the black parts are cut of of these subclips.
    I did remove all in and out points.
    Does anyone know what I’m doing wrong?
    Thx!
    Pieter Smet replied 8 years, 11 months ago 2 Members · 2 Replies
  • Payman Naderi
    September 9, 2017 at 3:48 pm
    hi
    make sure in export window you select work area if your subclips is occupied all of timeline.
    or just select the part you need with in and out point with shortcut of (I&O) and in render window select
    in and out point.
    when some part of your final export is black because you maybe select (with in and out points) some area of your timeline wich is empty.
    i hope i understand your problem then i wish it helps you.
    payman naderi
    payman.naderi744@gmail.com
  • Pieter Smet
    September 9, 2017 at 4:20 pm
    I am not trying to export them from a timeline. I just export the clips straight from the bin.
