Activity › Forums › Boris FX › Export Stills Come W. Checkerboard
  • Export Stills Come W. Checkerboard
    Posted by Peter Tours on April 25, 2009 at 1:42 am
    Red 4.3.1 and as I remember all vers of 4, whenever I export a pict (command shift M) unless I reset the prefs to factory, I get the checkerboard (or black) bkd of the composite window. My questions are why and how?? Thanks, peter
    Peter Tours replied 17 years, 4 months ago 2 Members · 4 Replies
  • Peter Mcauley
    April 25, 2009 at 2:45 am
    You can control this behavior in the Compression Settings dialogue box, which is in the menu that appears when you select export movie file. If you want to include the transparency from the comp then select a codec that supports alpha and set it to millions of colors plus.
    Cheers,
    Peter.
  • Peter Tours
    April 25, 2009 at 3:42 pm
    I use either pict, png or psd and they all had the same problem…on several systems. Never used to have that problem before 4. Man it’s nice to have someone to share with about Boris. Thanks!
  • Peter Mcauley
    April 26, 2009 at 1:32 pm
    I’m not sure what changed but it sounds like you now have a handle on the issue. Glad I could help.
    Cheers,
    Peter.
  • Peter Tours
    May 7, 2009 at 10:27 pm
    Maybe I wasn’t clear. Not movies, stills….there is no menu for stills. Is there?
