Activity Forums Apple Final Cut Pro Legacy export still frames based on sequence markers
  • export still frames based on sequence markers
    Posted by Jason Brown on December 14, 2010 at 2:41 pm
    I have 15 sequence markers…I’d like to export TIFF still images from each of the points in the timeline based on the markers.
    Is there a way to do this? I searched and couldn’t find relevant results.
    -Jason
    Morgan Mendieta replied 14 years, 6 months ago 4 Members · 8 Replies
  • 8 Replies
  • Rainer Wirth
    December 14, 2010 at 3:04 pm
    You have to go manually from one marker to the next and export The still image. That’s the only way I know of.
    Rainer
  • Patrice Freymond
    December 15, 2010 at 11:29 am
    Should work if:
    1) you put your sequence in a bin
    2) turn markers into subclips (if you have v.7)
    3) export the subclips as stills
    hope this helps
    patrice
  • Jason Brown
    December 15, 2010 at 12:16 pm
    I am on v7…I’ll try this! Thanks 🙂
  • Jason Brown
    December 15, 2010 at 3:20 pm
    [Patrice Freymond] “you put your sequence in a bin”
    What do you mean by this? Sequence already exists in the browser. No toggle down to reveal markers and make subclips. This only works with clips.
    -Jason
  • Patrice Freymond
    December 15, 2010 at 6:15 pm
    Sorry, my bad. This won’t work.
    What does work is if you mark your sequence clips with markers, drag those clips in a bin and make sublips from the markers. You can then export the stills.
    But it is not, unfortunately, the easy automated way you were looking for…
    again, apologies fr misleading you.
    patrice
    Patrice Freymond
    Senior editor
    FCP Certified Trainer
    patrice@monteur.tv
  • Morgan Mendieta
    March 9, 2012 at 12:26 am
    I was looking for a way to do this myself.
    I have about 50+ images I need to export per sequence / video
    This was my solution.
    Steps:
    1. Select my shots with markers
    2. Edit each markers Out Point in the browser to the same as the IN point. “Copy In point, Paste to out point”
    3. Then I take my markers and drag them into a flat timeline like 25 FPS
    4. Batch export each timeline to Image Sequence at 25 fps.
    Not automated but saved me lots lots of time.
  • Jason Brown
    March 9, 2012 at 9:15 am
    I was able to do something similar using the export queue.
    If you make markers, then drag them to a folder and add them to export queue, you can use the in point and export still image from the export queue to send out frames. No need to copy in and out points.
    -Jason
  • Morgan Mendieta
    March 9, 2012 at 7:16 pm
    Oh yes It works. Great, time saver.
    I think I attempted this before but i did not put markers into new bin and it kept crashing.
    Also on my solution which is not obsolete no need to copy in and pase in and out points,
    simply make clip length to 00:00:00:01, just copy that into every marker clip.
