Activity › Forums › Apple Final Cut Pro Legacy › Export size changes
  • Export size changes
    Posted by David Perry on June 17, 2008 at 8:21 pm
    I am exporting a letterboxed DV25 project. In the timeline it looks fine. But on export it stretches. My sequence settings are
    Frame size 720×480 NTSC DV 3:2
    Pixel NTSC-CCIR 01 DV NON Anamorphic
    Field Lower
    Compressor DV.DVCPRO NTSC
    THe files are exactly the same. If I change the timeline to 4:3 it causes a huge render but then it squeezes it.
    Does anyone know what I am doing wrong?
    On Capturing from a HVX-200 in DV mode the files look a bit stretched in quicktime but OK in the timeline.
    Thanks in advance.
    David PErry
    David Perry
    Carmen Productions
    Eric Johnson replied 18 years, 3 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    June 17, 2008 at 8:48 pm
    How are you judging the export? In QuickTime? What are you exporting as? DV? or?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • David Perry
    June 17, 2008 at 9:45 pm
    I am exporting a quicktime file both reference and self contained. In the export process it stretches. It is not as big a difference as going from 4:3 to 16×9 but it is very prominent. Then I import it into compressor and I was hoping to use a pillar effect to bring it into perspective, but I can’t find one.
    David Perry
    Carmen Productions
  • Eric Johnson
    June 18, 2008 at 12:26 am
    Have you brought the export into FCP? If so does it look fine there? DV isn’t a square pixel format, which will cause this sort of distortion. QT does not always account for non-square pixel formats. So, the file maybe right, it’s just that the viewing environment is not.
