Activity Forums Avid Media Composer Export single clip (with handles ) from timeline for VFX dep ?
  • Export single clip (with handles ) from timeline for VFX dep ?
    Posted by Jeremie Galan on December 13, 2014 at 1:17 pm
    Fairly new to Avid and wondering what was the best way to send out/export one of my edited clip ( with correct tc, edit points ( with added handles ) to my vfx artist ? The project is dnxHD185 so no need to go back to the original file.
    And second, what is the same workflow if my clip is in dnx36 and i need to reference to the original file, but again with the correct in/out points, handles etc )
    Best regards
    Jeremie.
    Jeremie Galan replied 11 years, 9 months ago 2 Members · 2 Replies
  • Michael Phillips
    December 13, 2014 at 7:26 pm
    If you need to send media (essence), drag the events into their own timeline (copy/paste, or subsequence). Then with that new timeline of just the events of VFX, you can consolidate the media with handles to a target drive then send to your artist.
    If metadaa only, then for the same sequence of VFX events created in prior process, use “decompose” to create a new set of clips with defined handles, drag those clips to a timeline, then generate an EDL or AAF depending on what their system supports which will have the info they need to go back to the original sources.
    Michael
  • Jeremie Galan
    December 13, 2014 at 10:03 pm
    Great thank you a lot !
