Activity Forums Apple Final Cut Pro export, share no option to export
  • export, share no option to export
    Posted by Robert Ellison on July 31, 2014 at 9:26 pm
    I have selected a project in the timeline and attempt to export it but export does not appear in the choices, only share. When I click on share it shows me that the size of the file is 9gb. the actual file that I imported into fcpx was 25 mg. Why is this happening and how can I get an exportable file that is not so huge?
    Denes Ujvari replied 12 years, 1 month ago 3 Members · 2 Replies
  • Tim Jones
    July 31, 2014 at 10:31 pm
    When you click on “Share”, one of the options is “Master File (default)…”. This is the option to export to disk. Once you select that setting, you can choose the CODEC settings that you want to use for the export. If you use the same settings constantly, you can create a new entry in the Share menu that has those settings as the defaults.
    HTH,
    Tim
    Tim Jones
    CTO – TOLIS Group, Inc.
    https://www.productionbackup.com
    BRU … because it’s the RESTORE that matters!
  • Denes Ujvari
    August 1, 2014 at 1:15 am
    Export the file as QT file and choose H.264 as the codec
    Export the clip via compressor and set the size
    Or use something like MPEG SyreamClip to compress and determine the file by using limit data size !
    digital-den
