Activity › Forums › Adobe Premiere Pro › Export settings??
Export settings??
Posted by Fred Pedersen on May 19, 2011 at 12:44 pmHello,
I’m having a problem getting decent quality exports from premiere:
The image on the left is the source and on the right is the screen capture of the video. You can see the compression is making the blue background blocky. Is there a type of compression that will avoid this? Size is not a huge problem but I’ve tried putting the bitrate up to 300 and it still comes out like this.
Note: oddly when I put the bitrate up premiere estimates the file size at 300mb but the final size is 20mb?
Thanks for any help 🙂
Fred Pedersen replied 15 years, 4 months ago 3 Members · 6 Replies -
Jeff Greenberg
May 20, 2011 at 1:17 amThe larger the data rate, the larger the finished file. 300 kbs is probably too low. Try 1,000 and see if the problem goes away.
Best,
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
You should follow me (filmgeek) on twitter. I promise to be nice.
Come See me speak at NAB!
Compressor Essentials from Lynda.com
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
Contact me through my Website -
Jeff Pulera
May 20, 2011 at 1:42 pmHi Fred,
It will be helpful if you can share some specs. What is the source video – 720×480? What format are you exporting to – DVD, H.264, .wmv?
Jeff Pulera
Safe Harbor Computers -
Fred Pedersen
May 20, 2011 at 2:12 pmHi Jeff,
The source video is 1280 x 1024. I’ve tried exporting to a few different formats including h 264, wmv and avi…
Fred -
Fred Pedersen
May 20, 2011 at 2:21 pmThe outputted file says its data rate and total bitrate are 2435kbps. In premiere I’ve set the target bitrate to 240 Mbps (the max as far as i can tell) for VBR and 300Mbps at CBR and still the filesize is small, about 10mb, and has the same problem. I’ve set the ‘level’ to 5.1 as I get the impression this limits quality when lower?
These settings are when using the h 264 format.
Thanks for any help
Fred -
Jeff Greenberg
May 20, 2011 at 2:34 pm[Fred Pedersen] “The outputted file says its data rate and total bitrate are 2435kbps. In premiere I’ve set the target bitrate to 240 Mbps (the max as far as i can tell) for VBR and 300Mbps at CBR and still the filesize is small, about 10mb, and has the same problem. I’ve set the ‘level’ to 5.1 as I get the impression this limits quality when lower?”
h.264 is definitely going to give you the best results.
How are you determining the outputted files data rate? You’re writing it kb/s – and some stuff in Mb/s – let’s make it all Mb/s. Your outputted file is at 2.5 Mb/s, yes? Working backwards – a 10 mb file @ 2.5 Mb/s means your original is around 30 seconds?
In Premiere Pro, you’re saying you’ve set the target bitrate at 240 mbs? On export of Media right? That should yield a HUGE file. 100x 2.5mb/s
When I open Premiere Pro and adjust the Target bitrate, the estimated file size at the bottom is adjusting as well (it is for you too, right?)5.1 is the fifth revision – it’s a compatibility level – some devices won’t handle 5.1 complexity (but all computers will).
Sorry to ask this – you have Use Ma Render quality ON and use Previews OFF, right?
Best,
Jeff G
Fred Pedersen
May 20, 2011 at 2:50 pmYeah, sorry, I got the kbps from windows explorer file properties, its outputted at 2.5mbps and is 24secs long.
Thats does seem to be something that is going wrong, premiere estimates the file size at 700 mb but only yields a 7mb file??
Full settings:
Output ntsc 680 x 544 h 264, 24fps, progressive, no audio, vbr 2 pass 240Mbps
Source is 1280 x 1024, 24fps – originally each frame is a tiff image at the same resolution imported into premierRendered at maximum depth (not fully sure what this does, I was hoping color depth), with max render quality on and previews off.
Fred
