Activity › Forums › Adobe Premiere Pro › Export Settings from CS5.5
  • Export Settings from CS5.5
    Posted by John Frey on August 15, 2012 at 7:06 pm
    I have just completed an HD 11 part tutorial project destined for DVD, BluRay and a host web server. I have completed the DVD and BluRay portion. The company who hosts my client’s project usually encodes all uploads to their server to the following:
    video codes: H:264/avc
    Frame size: 720 by 540
    Bitrate: 450
    Frame rate: 25 fps
    File type MP4 iso v.2
    Audio codec MPEG-2/4 audio
    Sample rate: 44100Hz
    Bitrate: 48kbps
    Channels: Mono
    Using their settings in Premiere 5.5, I looked at which H.264 export settings might be a starting point. They are asking for 25fps which is a PAL thing, but I only find AAC audio available. Anyone out there who can suggest an export starting point for these required settings that I can then modify.
    I can just upload the originally edited HD files to their server, and they will encode them, which they do for most of their customers. But the upload times of these big HD files would be tedious. I am hoping for better quality on their server and less time spent on the uploads by encoding them myself, which they have agreed to as long as I can match their specs. Anyone?
    John D. Frey
    25 Year owner/operator of two California-based production studios.
    Digital West Video Productions of San Luis Obispo and Inland Images of Lake Elsinore
    Dennis Radeke replied 14 years, 1 month ago 2 Members · 1 Reply
  • Dennis Radeke
    August 16, 2012 at 12:05 pm
    If you need audio in MPEG, then try Quicktime as the format in Premiere Pro which will give you some other audio export options.
