Activity Forums Apple Motion Export settings for TV commercial?
  • Export settings for TV commercial?
    Posted by Steve Voltmer on March 2, 2010 at 4:19 pm
    I am using Motion to create some animation to export for Final Cut Pro, but when I import it into Final Cut all the objects in the animation look jaggie or a poor resolution. What settings should I export the Motion file at for SD TV broadcast? Thanks
    Stephen Smith replied 16 years, 6 months ago 2 Members · 3 Replies
  • Stephen Smith
    March 2, 2010 at 4:41 pm
    When you Export make sure you set it to Best.
    Or you can bring the Motion Project File into FCP and render it there. If you do do that make sure you go to Sequence, Settings, Render Control tab and then set Quality to Best.
    Hope this helps and best of luck.
    Utah Video Productions
    Check out my Motion Tutorials
  • Steve Voltmer
    March 2, 2010 at 6:17 pm
    Thanks, rendering inside of FCP was the only thing that worked, but it renders the whole motion project and doesn’t stop at the outpoint I set in Motion. What do I do to make it only use the part of the project between the in and outs in Motion?
  • Stephen Smith
    March 2, 2010 at 6:53 pm
    You can shorten the length of the project in Motion or in Final Cut Pro so you don’t have to render the whole project.
    When you Export you should: File, Export. Click on Options…, Click on the Output tab, uncheck the Use Current project and Canvas Settings checkbox. Change Render Quality to Best. OR just simply change the Render Quality to best.
