Activity Forums Apple Final Cut Pro Legacy export settings for keying
  • export settings for keying
    Posted by Hamish Boyd on May 2, 2005 at 11:45 pm
    Just wondering what the general consensus is with exporting from FCP to after effects with regards to compression settings. I have digitised miniDV via firewire and now exporting to AE. At the moment I am exporting using the animation codec at 100%. Is that the best way, or am I just churning through disc space and time for exporting and instead should be doing something else.
    Any thoughts?
    Trying to avoid any re compression of dv footage.
    Cheers
    Seamus
    Jerry Hofmann replied 21 years, 3 months ago 2 Members · 3 Replies
  • Jerry Hofmann
    May 3, 2005 at 4:26 am
    Why not just open the DV captured clip in AE? You’ll not gain anything exporting it with the animation codec… General rule of thumb: the less you do to a media file once captured, the cleaner it stays…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Hamish Boyd
    May 3, 2005 at 6:07 am
    yeah, I was tinkering with the export as a reference and I know it is just a reference back to the source clip. But it looked really bad. Really soft. The ani export as its own clip was better. Why is that?
    Also, if you are exporting certain clips, and you turn off the box- “make self contained”, therefore in theory making it a ref clip, why do you still get the settings window to set the codec. If its a reference, that doesn’t make sense. Which one do I select?
    Cheers
  • Jerry Hofmann
    May 3, 2005 at 1:04 pm
    Should set it to use current. (the default setting)
    Jerry
