Export settings confusion
Hello, bit of a novice question here.
So I worked with a video in 25fps in FCP7. I used the Slow Motion on the frames and they are now showing 50fps when I right click and look at attributes. My Sequence also seems to be 50fps, though I’ve just created another one at 25fps and copying over the files worked (however they are still 50fps of course).
I want to export using Avid DNxHD to 25fps, 1920×1080.
However, am not so sure what to select? When selecting Avid DNxHD from the dropdown (Export using Quicktime Conversion) menu, should I enter 25fps into the Frame Rate?And secondly or the “Size” button: Do I select 1920×1080 here? My current size is shown at 640×360.
Many thanks!
