Activity Forums Adobe Premiere Pro Export settings changed, can’t change back?
  • Export settings changed, can’t change back?
    Posted by Steve George on July 28, 2009 at 4:25 pm
    Hi Guys, some help needed please.
    I use adobe premiere pro cs4 quite a lot and always have same same settings and export as mp4 h.264 with aac audio.
    My setting have changed somehow and i can only export as m4v ?
    when i do this, it exports my audio and video separately.
    I have played with all the settings but cant seem to find how to get back to my standard export formula of mpg.
    Please advise 🙂
    Vince Becquiot replied 17 years, 1 month ago 2 Members · 3 Replies
  • Vince Becquiot
    July 28, 2009 at 4:46 pm
    Check the multiplexer tab, it should be set to mp4, standard.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Steve George
    July 28, 2009 at 4:59 pm
    Thanks for the fast reply vince, i tried what you suggested but it didnt work. when it displays my output destination, it says ….mp4, but when media converter opens it still says ….m4v and splits the audio and video.
    Is there anything else that can be causing this ?
    Ta
  • Vince Becquiot
    July 28, 2009 at 8:17 pm
    During encode, you will see that separate AAC file, but it will disappear after the encode is completed, as this is when the multiplexing happens (Combining the 2 files into a single stream)
    Vince Becquiot
    Kaptis Studios
