Activity › Forums › Adobe Premiere Pro › export settings
  • export settings
    Posted by Ruby Gold on July 13, 2006 at 7:25 pm
    I’m in PPro 1.5 and have always exported my timelines with settings for DVD. A client needs me to just export footage for them to edit and has asked that it be in Quick Time format. In the export settings I was planning on selecting Movie Settings>File Type>Quick Time>Video Compressor>None.
    Wd this be correct?
    Also, I shoot in mini-DV format, and if I were to export from movie settings for AVI files, should I select the File Type as Microsoft AVI or Microsoft DV AVI? I’m assuming the latter, but, any info on which is better (and why) wd be appreciated.
    I’m also assuming that in both cases the “Recompress” box should be checked with “maintain data rate” in the pulldown. Correct?
    Thanks a lot-
    Ruby
    Hector Melendez replied 20 years, 2 months ago 4 Members · 5 Replies
  • Joshua Earles-bennett
    July 13, 2006 at 7:31 pm
    I like Quicktime H264. It’s a good size and is very clean.
  • Ruby Gold
    July 13, 2006 at 7:57 pm
    Thanks for the response, but because the client will be editing this footage, I don’t want to step on it–hence the uncompressed video setting.
    After exporting though, I noticed two things–one is that the video was distorted–too wide, and the second is that it wouldn’t play back in the QT viewer or PPro without stuttering badly. I tried exporting with “square pixels” rather than my usual 0.9, and that fixed the distortion, but I’m wondering why it’s stuttering. Doesn’t do so when I export without compression as an avi.
    Should I export as square pixels or .9 and any explanation for the stuttering?
    thanks-
  • Blast1
    July 13, 2006 at 10:19 pm
    The best thing is to ask the person who is going to edit the QT what they perfer as a format, if they don’t have a choice you can use none or sometimes I use Planar RGB, don’t recompress as it can add artifacts and also keep the 720×480 with the .9 aspect ratio.
    If you are working in DV AVI its best to export to the same, unless you need VFW, also don’t recompress.
  • Blast1
    July 13, 2006 at 10:35 pm
    >any explanation for the stuttering?< What kind of format does your original audio files have? for DV its usually 48khz, 16bit uncompressed .wav, 1 frame interweave, use the same for the QT audio
  • Hector Melendez
    July 14, 2006 at 4:39 am
    Why not you give to your customer the Mini DV raw? Can’t be more “clean”
