Activity Forums Adobe After Effects Export settings
  • Export settings
    Posted by Nina Bjer on December 2, 2009 at 9:06 am
    Hello!
    I have edited some films in After Effects and want to export them to Quicktime format, but am a little confused about which settings to use. I film in HD qaulity and want to keep it as good as possible. I would like to export to a format that I can use for both DVD and sites like Vimeo. When I output the films now it takes about 15 hours for three minutes of film! And also the file size is larger than 500 MB… So I would be very happy if anyone could help me a little with this! 🙂
    The settings that I’m using are these:
    – Compression codec: H.264 (I would like to keep this but rather change some of the below settings)
    – Framerate: current
    – Quality High (or should I use Best?)
    – Dataspeed/datarate: Automatic, or I read that 5000Kbit/s was good for HD (this setting apparently detemines the filesize which I need to reduce)
    – Size HD 1280×720, 16:9
    – Letterxox and Deinterlace
    – Sound: I read that I should choose AAC, but there isn’t any such option. I can choose 24 bit, alac etc, but don’t understand this so I choose uncompressed. 44.100 kHz
    Very grateful for any help!
    Kind regards
    Ninja
    Nina Bjer replied 16 years, 9 months ago 31,335 Members · 3 Replies
  • Nina Bjer
    December 2, 2009 at 8:03 pm
    Thank you very much Dave! This was news to me and very very good to know! And good to hear that it isn’t just me not getting what to do! 🙂 I’ll have a look at that Forum instead!
    Again, thanks so much!
    Ninja
  • Nina Bjer
    December 3, 2009 at 8:12 am
    But what settings should I have for the high quality file from AE then? The once I’m using takes forever and or crashes after a day or so. I have put my question in the Compression Techniques forum, so hopefully I’ll get some help there too! Thanks!
    Ninja
  • Nina Bjer
    December 4, 2009 at 9:36 am
    Thanks so much Dave! :)I’m self tought so yes I’m probably making al kinds of mistakes! 🙂
    – For example, I don’t knor how to use/not use Opel GL…?
    – I did have the multiprocessing of, I’ll try with it on now mut if that doese’t help I’ll turn it of again.
    – How do I know if the HDV footage is/isn’t still in its acquisition codec?
    Yes I’m on Windows, but I’ll try Animation if it still doesn’t work with H.264 (this is a sugestion from Vimeo, where I put the films).
    Anyway, thanks so much! 🙂
