Activity Forums Apple Final Cut Pro Legacy export settings
  • export settings
    Posted by Jessica Shaughnessy on September 8, 2010 at 9:32 pm
    Hi
    I am filming press conferences for a client who has asked for very specific export settings.
    Here they are:
    Wrapper: MOV (QuickTime Movie)
    Video Codec: Quicktime DV PAL Standard Def
    Video Compressor Quality: Best Quality
    Video Frame Size: 720×576
    Video Frame Rate: 25 fps
    Video Aspect Ratio: 16:9
    Key Frame: Every 50 frames
    Audio Codec: Uncompressed or PCM (Little Endian)
    Audio Channels: 2 (Stereo)
    Audio Sample rate: 48000
    Audio sample size: 16bits
    A/V Duration synchronisation: on
    The footage needs to be interlaced and not progressive.
    It’s also important that you shoot and encode upper/odd filed first interlaced video.
    The ‘stream type’ should be ‘non-streaming (not hinted) too.
    If there is any options when exporting to provide an alpha channel this need to be unchecked or ‘ignored’.
    I’ve just done a test and if I export using DV pal compressor type, the “key frame every option gets greyed out”.
    How do I change it?
    Also, and I appreciate this is not a camera forum, but how do I ensure I shoot in upper/odd field interlaced video. I have only ever seen this in the editing settings. Am I missing something?
    Any help appreciated, thanks in advance
    Jess
    John Pale replied 16 years ago 2 Members · 2 Replies
  • Jessica Shaughnessy
    September 8, 2010 at 9:37 pm
    Also, I can’t see and option to turn the A/V Duration synchronisation on.
    Apparently, if we can’t adhere to these settings, we can’t do the work. How important is the duration synchronisation anyway?
    I may be being completely ignorant
    Jess
  • John Pale
    September 8, 2010 at 9:38 pm
    Your client is a little confused.
    DV has no key frames. Its a constant bit rate of 25 Mbs.
    Unlike other PAL formats, DV PAL is Lower Field First.
    You cannot change these these things to satisfy your client. They are “hard wired” into the codec.
