Activity Forums Media 100 Export settings
  • Export settings
    Posted by Sue Daly on December 21, 2010 at 3:09 pm
    Hello,
    Can any one tell me where I’m going wrong with exporting from my Meida 100 edl to create a 16×9 Quick Time Movie? (I’m using Media 100 Suite) My work is all in 16 x 9 but whenever I export anything it creates a 4×3 movie. I can convert it to 16×9 in Quick Time Pro but when I send it to a conversion web site, I use BlipTV so that I can use it on my own web site, it comes out as 4×3 again. It’s driving me nuts!
    Sue
    Sue Daly
    Floh Peters replied 15 years, 8 months ago 3 Members · 6 Replies
  • Eric Pelletier
    December 21, 2010 at 3:36 pm
    is this 4×3 movie looking squeezed horizontally? (Or streched vertically?)
    If so, it’s normal since you’re outputting an anamorphic 16×9 movie.
    If you want it to look “normal” on a computer screen, output to 16×9 with these dimensions :
    PAL 1024×576
    NTSC 854×480
    NTSC 864×486
  • Sue Daly
    January 11, 2011 at 2:17 pm
    Many thanks – with apologies to taking three weeks to reply!
    Sue Daly
  • Sue Daly
    January 12, 2011 at 7:42 pm
    Me again, still struggling with export setting from Media 100 Suite. I’m now trying to create a DVD (PAL) that will play on a computer and in a standard, hooked up to a telly DVD player in 16×9. My project is filmed and edited in 16×9. I’m using iDVD to make the DVD. So far I can make a 16×9 DVD that is horribly cropped way beyond the safe area setting in iDVD or I can make a DVD that ends up being 4×3. Where am I going wrong?
    Sue Daly
  • Floh Peters
    January 13, 2011 at 3:01 pm
    Hi Sue,
    what version of iDVD are you using? I think I remember that some iDVD versions only supported 4:3 media. Is there a 16:9 setting in your iDVD version?
  • Sue Daly
    January 13, 2011 at 3:54 pm
    Hi Floh,
    I’m using iDVD6 and it does offer the option of 4×3 or 16×9.
    All the best,
    Sue
    Sue Daly
  • Floh Peters
    January 14, 2011 at 3:54 pm
    Hi Sue,
    locate the exported QuickTime in the Finder. Open it in QuickTime Player (Pro). Under Movie Properties (Command-J) select the Video Track, and set the “Scaled Size” (under the Visual Properties tab) to 1024*576 for PAL or to 864*486 (if my math is correct) for NTSC. Save the file and open the file in iDVD again.
    One additional note if you are working in NTSC: I am not sure if iDVD does the 486->480 (for MPEG2) conversion correctly. If you are seeing interlacing artifacts, you could export a DV Stream from Media 100 instead a by-reference or self contained movie. This should be in 720*480 already, which is perfect for DVDs. Then set the size to 854*480 in QuickTime Player and continue to iDVD.
