Activity Forums Apple Final Cut Pro Legacy Export settings 16×9 for the web
  • Export settings 16×9 for the web
    Posted by Jay Wolf on December 16, 2006 at 3:24 pm
    I’m having serious problems exporting a 16×9 sequence to a 16×9 webfilm. I can’t seem to get a 16×9 .mov, tried all sorts of things but keep getting 4×3
    Tried these settings in Compressor:
    Quicktime 7 for download 300 Kb/s
    First I just left everything at default, assuming Compressor will export the 16×9 sequence as a 16×9 QT movie.
    Then I messed with the Inspector, consecutively:
    Frame Size: 50% of source
    Pixel Aspect: PAL Anamorphic
    Constrain to display aspect: 16×9
    None of them played 16×9 when I played it in Quicktime. (Then I dragged it into iWeb, thinking it might be played as 16×9 there, but no go…)
    What am I missing? Thanks very much for your help,
    Wolf
    Jay Wolf replied 19 years, 9 months ago 3 Members · 5 Replies
  • Jerry Hofmann
    December 16, 2006 at 4:45 pm
    Well, with a H.264 setting, I can get anamorphic DV to come out 16:9 by setting the pixel aspect ratio to DV anamorphic, and constraining the aspect ratio to 16:9… Does this help?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Bill Kelly
    December 16, 2006 at 6:17 pm
    Try exporting Using Quicktime Conversion, then click Options, then Size, then Custom Size. Enter your 16:9 numbers. I think that should work.
  • Jay Wolf
    December 16, 2006 at 7:36 pm
    You’re GOLD, Jerry. And I must be an idiot… that must be the only option I didn’t use… But why doesn’t Compressor adapt the aspect ratio settings from the FCP sequence? It is not very user-friendly, is it?
    Thanks (also to Kelmedia for pitching in- ‘there are more roads that lead to Rome’ is a Dutch saying, I’ll give yours a shot as well)
    Wolf
  • Jerry Hofmann
    December 16, 2006 at 7:55 pm
    You can create a preset for this.. it’s just that Compressor doesn’t include one… after you setup the changes I posted, just save as… and it will be availalbe with a click from the custom presets folder in Compressor…
    Jerry
  • Jay Wolf
    December 17, 2006 at 1:08 pm
    Thanks again, Jerry.
    Wolf
