Activity Forums Adobe After Effects Export setting for YouTube
  • Export setting for YouTube
    Posted by Alex Kittavong on March 2, 2010 at 5:48 pm
    Hey everyone, I have some questions about After Effects and YouTube. I have read some threads about it, but i still have other questions.
    I made a short movie, which is about 9 minutes long. It’s size is 1280 x 720. I never had this problem before until now and the problem is that it quits rendering at least halfway or more than halfway across the rendering process. Here’s my computer specs and export settings:
    CPU Specs:
    i3 processor
    4GB DDR3
    500GB hard drive
    Export Settings:
    Quicktime video
    Photo JPEG
    Medium quality
    Default audio setting
    I’m trying to keep it under 2gb for youtube, if you guys have any suggestions for the export settings, please let me know.
    Also if someone can please explain the rendering issue I’m having. I googled it and it seems that none that I found is helping me.
    Regards,
    Alex
    Alex Kittavong replied 16 years, 6 months ago 2 Members · 6 Replies
  • Michael Szalapski
    March 2, 2010 at 6:19 pm
    Do you get any error messages when AE quits?
    Do you have multiprocessing turned on? (If so, turn it off, you don’t have nearly enough RAM for it.)
    As to your output, read what Dave LaRonde has to say in:
    Dave’s Stock Answer #3:
    Don’t use AE to compress files for final delivery. The various compressors are there only to make quick ‘n dirty files showing a project’s progress to producers, clients, the kids, etc. AE is incapable of doing multipass encoding, a crucial feature that greatly improves the image quality of H.264 and MPEG-type files in particular.
    Render a high-quality file from AE, and use a different application to do the compression. Popular ones are Adobe Media Encoder, Sorenson Squeeze and Apple’s Compressor, which comes bundled with Final Cut Suite. Even compressing in Quicktime Pro is better than compressing in AE.
    Making good-looking compressed files is almost as much an art as it is a science. It is NOT straightforward at all. I recommend asking a few questions at the COW’s Compression Techniques forum.
    For YouTube HD, I’ve used Adobe Media Encoder and done Quicktime with H.264 codec and it looks fine and has a reasonably small file size.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Alex Kittavong
    March 2, 2010 at 6:23 pm
    Thanks for the quick response. I will check if the multiprocessing is turned on. Is the Adobe Media Encoder free?
    Thanks for the very helpful tips. I will put those tips to use when I get home.
    Regards,
    Alex
  • Alex Kittavong
    March 2, 2010 at 6:30 pm
    Nice, Thanks for the heads up. Some very useful tips. Also i do have another question. I watched the video after it quit rendering out of no where and i noticed in one section of my movie, it sort of “glitches” like it skips or whatever. I watched tthe raw footage and it seems fine. What would be the cause of that?
  • Alex Kittavong
    March 2, 2010 at 7:06 pm
    Very interesting. So, the HDV files should be converted to atleast AVI right? I have a video converter program called “imTOO Video Converter Ultimate.” They give the choice to convert to HD AVI, would that be good to import into AE and have it not freak out?
  • Michael Szalapski
    March 2, 2010 at 8:48 pm
    The Adobe Media Encoder comes with the Creative Suite. If you have Premiere, you’ll have the Encoder. If not, you’ll have to use something else.
    – The Great Szalam
  • Alex Kittavong
    March 2, 2010 at 9:07 pm
    Gotcha, Thanks a bunch!
