Activity Forums Adobe Premiere Pro Export Sequence without Re-encoding
  • Export Sequence without Re-encoding
    Posted by John Pilgrim on June 5, 2013 at 9:51 pm
    FWIW, I’m used to a FCP7 workflow.
    I have a sequence containing ProRes Proxy footage.
    Is it possible to export the sequence to a ProRes Proxy MOV and NOT have Premiere decompress and recompress the footage?
    Specifically for my question, it could be any intra-frame codec, as from the ProRes or DNxHD families.
    In FCP7, if the source, sequence and export codecs (and other settings) all matched (with an intra-frame codec), the FCP would not re-encode the footage, but rather copy the appropriate frames from the source to the export MOV.
    How does Premiere funtion in this regards?
    John
    Kris Merkel replied 13 years, 3 months ago 3 Members · 2 Replies
