Activity › Forums › Adobe Premiere Pro › Export sequence in/out points changed in CC 2018?
  • Export sequence in/out points changed in CC 2018?
    Posted by Mateo Brooks on March 2, 2018 at 2:10 pm
    Our previous work computer used CS5.5, and a small feature I used was the in/out point on the sequence, the shortcut used to be alt-[ but it no longer works.
    I noticed in CC, Alt-[ does nothing, but you can do something similar for exporting a piece of a sequence using just the regular in/out points (i and o shortcuts)
    —-EDIT—–
    Completely forgot the about the Work Area Bar, it doesn’t show up in CC2018 by default but I’ve figured it out! Problem solved!
    Tero Ahlfors replied 8 years, 6 months ago 2 Members · 1 Reply
  • Tero Ahlfors
    March 2, 2018 at 2:17 pm
    You can enable the work area bar from the timeline panel menu. Click on the three lines next to the sequence name.
