Export sequence from AE to FCP : frame rate issue
I’ve been working on some animations that I want to import in Final Cut Pro 6. My document in After Effects is in 29,97ips. When I export it from AE in a Quicktime sequence, I manually choose 29,97ips.
When I import that sequence in FCP, after rendering it, it doesn’t seem fluid. When I check the sequence’s properties, it says that the sequence is in 23,98ips even tho I made sure to create it and export it in 29,97ips.
Any ideas!?
